Propeller simulation
Old   August 18, 2014, 07:41
Default Propeller simulation
leon_jar is on a distinguished road
HI,
I'm looking for help regarding simulation of a propeller. I simulate only 1 blade air propeller (periodicity used). Model settings: Steady state, one rotating damain. I use SST fully turbulent model. Domain is rotating 4800 rev/min. I used Alternate Rotating Model. Velocity inlet :200m/s (stationary frame) farfield and outlet set as an opening (stationary frame) with Entrainment option. For both BCs static pressure value is set as relative pressure: 76000 Pa. Blade and hub walls are: no slip wall and adiabatic. The problem is that calculation is running only with Isothermal Heat Transfer option. When I try to change it to the Total Energy option, simulation gets divergent. I tried to start the simulation with energy on from RPM=0 and successively increase RMP till 2000 rev/m and it works but when I increase angular velocity more, ~3000 it gets divergent. The same situation when I restart the calculation from simulation without Heat transfer. After ~ 100 iteration it gets divergent. Does anyone could help me with this issue?
leon_jar is offline   Reply With Quote
Old   August 18, 2014, 19:32
The tips on this FAQ would be relevant here: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
I would be suspicious that some form of compressible flow thing is happening. Could shock waves be forming? I would put the residuals in the results file and save a series of results files as you approach the point where it crashes. Then have a look at the region of poor residuals and that might give you a clue as to what is going on.
Quadrotor helicopter propeller simulation Attesz CFX 14 December 4, 2017 16:45
Propeller calculation toil CFX 15 May 22, 2017 05:06
AMI - Propeller Tutorial diverging kingmaker OpenFOAM Running, Solving & CFD 2 November 4, 2016 03:57
Convergence of jet flow simulation MiraLisa FLUENT 0 August 15, 2013 05:44
Propeller Simulation Craig Paxton FLUENT 11 February 17, 2010 00:57
