August 17, 2014, 02:12 |
vorticity contour
mina
Rep Power: 13 |
Hi
I want to know how can i plot vorticity contour in cfx-post? i can't find vorticity in contour variables? |
August 18, 2014, 09:49 |
Rep Power: 33 |
Did you request the output of the Vorticity variable ?
Alternatively, is the Velocity.Gradient variable available ? In such case, you can compute vorticity using a CEL expression with the Velocity.Gradient components. |
August 18, 2014, 11:20 |
mina
Rep Power: 13 |
yes. Velocity.Gradient is available
thanks |
August 20, 2014, 02:59 |
Lance
Rep Power: 22 |
Vorticity can be found i cfd-post even if you didnt specify it in the preprocessor. Under 'Derived/Vortex Core' in the variable selector you can choose to plot Velocity.Curl, which is curl of the velocity field.
August 21, 2014, 02:50 |
mina
Rep Power: 13 |
http://uploads.im/3O6wu.png
http://uploads.im/yAXEV.png http://uploads.im/xnLBS.png the pictures are velocity, velocity curl and swirling velocity contours respectively. the swirling is the best one to show vortices but why its color is totally blue?? i want it to be like velocity contour. |
August 21, 2014, 02:52 |
Lance
Rep Power: 22 |
Change the color range?
Vorticity Contour | VSass | OpenFOAM Post-Processing | 12 | March 19, 2019 08:54 |
3D vorticity contour | shahzad_munir | Main CFD Forum | 0 | May 1, 2014 03:34 |
vorticity contour | achyutan | OpenFOAM Post-Processing | 0 | April 29, 2014 09:09 |
discontinuous region over Vorticity contour | jyh3134 | FLUENT | 0 | February 17, 2014 19:37 |
Vorticity Contour | maysmech | OpenFOAM | 3 | November 14, 2013 11:40 |
