August 8, 2014, 05:58 |
Publish REPORT from a CFD-Post macros
Franck
Hi everybody!
Context: I create an important number of Tables within CFD-Post. They are therefore all available in the Report section. Manually, I could simply click on Publish, and the job would be published Problem: In my post processing method, I would like to use my macros in batch mode. The problem is that I cannot find the command line in my macro to "export" a report (text format). I underlined the word "report" because the command ">export" only export an object type EXPORT (not an object REPORT). To all, thank you in advance for you time and consideration. Cordialement, Franck ps: I tried the command line ">report"... it did not work |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 10:26 |
Guide: Getting Started with the CFD Online Discussion Forums | pete | Site Help, Feedback & Discussions | 8 | July 29, 2016 06:00 |
Plotting Radial Velocity and Tangential Velocity in CFD Post | ashtonJ | CFX | 5 | July 13, 2015 03:49 |
View results at a contact region in CFD post | AGP | FLUENT | 0 | June 10, 2014 12:11 |
User CEL Function and CFD Post | chastain | CFX | 4 | September 24, 2013 14:58 |
