[Q] CHEMISTRY POST PROCESSING takes a long time...
Old   August 5, 2014, 21:24
Default [Q] CHEMISTRY POST PROCESSING takes a long time...
Jinwhan Ryuk
Whitebear is on a distinguished road
Does anyone have an experience that chemistry post processing takes a long time? I am solving coal combustion problem and pre processing solver takes one day but more than two days has taken for solver solves NOx calculation. How can I reduce the chemistry post processing time? I set 8 rays in radiation, upwind for advection scheme and 12 cores(hyper threading) parallel calculation for 1.2million nodes.
Whitebear is offline   Reply With Quote
Old   August 6, 2014, 09:21
I presume you mean the solver time is long - the pre- and post processing should be quick regardless of whether chemistry is present.
Yes, chemistry can make the equations less numerically stable and that leads to longer run times. "CFD" and "I need a more powerful computer" are often said together.
Old   August 6, 2014, 10:22
Opaque will become famous soon enough
Not sure what is the source of your problem; however, you should not run ANSYS CFX with hyperthreading on. Performance will suffer once you start running in parallel.
Opaque is offline   Reply With Quote
Old   August 8, 2014, 10:39
Default Thank you.
Jinwhan Ryuk
Thank you very much indeed ghorrocks and Opaque.
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
