FSI- Transient structural/CFX No structural results
Old   July 28, 2014, 17:43
Default FSI- Transient structural/CFX No structural results
Nas
Nastaran Sh is on a distinguished road
Hello All,
I am modeling a blood vessel which has a linear elastic material property of 2.5 e6 pa. It has a transient uniform inlet velocity changing from 0 to 0.3 and an outlet pressure of 1000 pa.
The geometry is a thin cylinder (thickness 2 mm) and has fixed BCs at both ends. Total time is 0.2 s. timestep 0.02 s.
The solution converges and give the results for fluid domain. I monitor the displacement of a point on the structure, and it seems to give valid results.
However, I cannot get the transient structural results. All values are 0 overtime. Could you help me with this?
To explain more, when I put a transient pressure on the wall. The results are ok for both domains.
Thank you
Nastaran Sh is offline   Reply With Quote
2-way fsi, cylinder flow, output file, transient structural
Initializing transient analysis using static analysis in two-way FSI simulation Daniel_Khazaei ANSYS 50 September 12, 2017 11:56
Collect transient results CFD POST mortain CFX 15 April 17, 2015 09:29
CFX and Transient Thermal Results bhavik139 CFX 6 March 29, 2013 15:04
Transient Run - Output "Time" in partial results? evcelica CFX 2 May 16, 2012 22:36
how to do time-averaging transient results azmir Main CFD Forum 0 May 8, 2004 06:53
