Modeling the effects of freestream turbulence on laminar heat transfer |
July 25, 2014, 11:12 |
I'm looking for a way to model the effects of freestream turbulence on laminar heat transfer. This is a well known effect and it can be seen on the front half of cylinders in crossflow and on the leading edge of airfoils. I can find a fair amount of literature documenting the effect, but I don't know of any common cfd models that handle it.
Also note that I understand freestream turbulence has an effect on transition, and that is fine, but what I am concerned with specifically is the effect on the heat transfer prior to transition. So far I have tried the SST model with the gamma theta transitional turbulence model turned on. But prior to transition, the effect of freestream turbulence on heat transfer appears negligible. Any suggestions? |
July 26, 2014, 06:20 |
Rep Power: 144 |
I do not think you can do this using a RANS model (even the turbulence transition model). You are going to have to use a LES model to capture this effect.
Best Turbulence Model for Heat Transfer in Jet Impingement | ara | STAR-CCM+ | 5 | July 25, 2014 11:45 |
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 12:44 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
turbulence flux closure for heat transfer | alinik | CFX | 3 | April 30, 2013 19:31 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 04:55 |
