July 25, 2014, 07:07 |
Sloshing of tank
liladhar
Rep Power: 14 |
Hi Everybody,
I am trying to simulate tank sloshing in roll motion. I successfully simulated tank sloshing given the periodic surge motion. But when i am give roll motion i am getting error. I am using CFX. The tank is given specified displacement. I am using cylindrical coordinate system. Following the expression i am using A = 0.17 [rad] Amplitude = if (t<=8[sec], A, 0[rad]) disp = Amplitude*cos (omega*t)*1[m]/1[rad] the error i am getting is ATTACHED IN FILE. |
March 12, 2018, 02:37 |
#2 | |
SAMBHU JAYACHANDRAN
Rep Power: 8 |
March 12, 2018, 09:54 |
urosgrivc
Rep Power: 12 |
It clearly says your mesh is of pour quality. Try some inflation layers on the walls if you dont have them allready. You dont have any mesh deformation enabled, do you? I mean because of the posibility to colapse the mesh near moving walls |
March 13, 2018, 07:25 |
Erik
Rep Power: 23 |
My guess is:
+--------------------------------------------------------------------+ | ERROR #002100027 has occurred in subroutine cNWDIST. | | Message: | | At least one highly skewed element has been detected on a wall | | boundary, leading to an unreliable near-wall distance calculation | | for the turbulent wall functions. The solver will continue | | to execute, but convergence and/or accuracy may be affected. | | Please consider improving the mesh quality. The coordinates of | | the element face are ( -0.3102E-02, 0.2000E+00, -0.1831E-02 ). | +--------------------------------------------------------------------+ but it's just a guess. |
May 1, 2018, 05:54 |
volume fraction axis changed
Rep Power: 10 |
hi,
i am facing a change in the axis direction in the final stage.The picture is added. kindly tell a solution..as the water volume should be horizontal(in green) |
May 1, 2018, 06:07 |
Gert-Jan
Rep Power: 28 |
Ask your question in the fluent forum.......
cfx 14, roll, sloshing |
water sloshing in oscillating tank (problem using udf Define_ZONE_MOTION) | Tamsu | Fluent UDF and Scheme Programming | 8 | November 24, 2021 01:11 |
inhomogeneous tank sloshing overflow error | enghamed | CFX | 1 | August 2, 2012 09:42 |
sloshing in tank | manoj kumar | FLUENT | 7 | July 30, 2011 06:53 |
tank sloshing - getting wrong pressure | enghamed | CFX | 2 | April 26, 2011 23:09 |
Tank sloshing in fluent diverging...need help | lostin4ever | FLUENT | 4 | February 24, 2010 08:20 |
