doubt criterion of convergence of the turbulence model
Old   July 21, 2014, 11:59
Default doubt criterion of convergence of the turbulence model
Talles Caio
TallesC is on a distinguished road
in my simulation consisting of an ode escoament one gas in a pipe, I specified crierio of convergence as a residue rms 1e-4 and 700 interactions. the simulation stopped at approximately 500 interactions, all variables reached the value of 1E-4 to the end, except the variable of turbulence, which may have occurred?
Obs. the model used was k-epson!!!
TallesC is offline   Reply With Quote
Old   July 21, 2014, 21:03
The only way to be sure is to run a sensitivity analysis. Do some simulations with tight and loose convergence tolerance on the turbulence equations and see if it makes a difference to the output variables of important to you.
Old   July 21, 2014, 22:06
Talles Caio
how I can change only the criterion of convergence of the equations of turbulence in CFX-PRE?
Old   July 21, 2014, 22:21
Just use different global residuals convergence tolerance and note the residuals of the turbulence equations.
Fluent :- turbulence Model prince_pahariaa FLUENT 9 May 20, 2016 04:41
Compressible turbulence model issues 351Cleveland OpenFOAM 5 October 24, 2013 16:41
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 05:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
turbulence model equation Andy Chen FLOW-3D 4 January 1, 2010 22:45
