Airfoil Investigation (changing angle of attack) |
July 17, 2014, 15:39 |
Dustin
Rep Power: 12 |
Over the past weeks, I have made decent meshes for different airfoils using ICEM and the simulations have been yielding good results (compared to experimental values). Up until now I have been manually changing the velocity components of the inlet flow to change the angle of attack which is rather time consuming. I now have to repeat this process many times for many different airfoils, and I was wondering if there were more efficient ways to go about this. I can think of some ways but I do not know if they are possible in ANSYS CFX -run one transient simulation where the angle of attach varies and record the forces on the airfoil at defined angles. -predefine all the velocities (like as txt file) and have ANSYS read in the velocities (kind of like a script file) and simulate all velocities in one run If anyone has any experience in this area, I would greatly appreciate your advice and comments. Thank you. |
July 17, 2014, 19:16 |
Rep Power: 144 |
You can do this in workbench using parameters. Alternately you can also do this with different CCL files and script them all together.
July 22, 2014, 03:52 |
Thrust Problem
M Mohsin Iqbal
Location: National University Sciencies & Technology, Pakistan
Rep Power: 12 |
Hi Sir
Hope so you will be fine and good. Sir i have a question regarding thrust of a propeller. Why Thrust of a propeller decreases with increase in Advanve Ratio??? Similarly Torque of Propeller ??? only propeller thrust and torque without engine. Thanks Looking Forward |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 17:17 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 10:48 |
[OpenFOAM] Plot Angle of Attack Next to Transient Pitching Airfoil | dancfd | ParaView | 6 | October 24, 2013 01:37 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
Varying Inlet Angle of Attack for Structured Hexahedral C-Grid around an Airfoil | Josh | CFX | 11 | June 22, 2010 22:27 |
