July 17, 2014, 05:15 |
Error #001100279
Rep Power: 13 |
Hi
I'm simulating a COLDPLATE and it show the following error can anybody explain why +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | SYMASS_CS_ELIM : The solver ran out of temporary space while buil- | | ding a linked list for a domain. Try setting the expert paramete- | | r "topology estimate factor" to a value greater than 1.0. Values | | higher than 1.2 should not be necessary. | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine POPDIR CRESLT = ILEG Current Directory : /FLOW/NAMEMAP +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | Warning! | | | | The ANSYS CFX Solver has written a crash recovery file. This file | | has been saved as C:\Users\lok\AppData\Local\Temp\Cold | | Plate-ks110-dau-2_3492_Working\dp0\CFX\CFX\Work1\Fluid | | Flow_001.res.err and may be an aid to diagnosing the problem or | | restarting the run. More details should be available in the | | solver output section of the output file. | +--------------------------------------------------------------------+ |
July 17, 2014, 07:03 |
Rep Power: 144 |
Have you done what the error message says? It tells you how to fix this......
July 20, 2014, 11:45 |
Rep Power: 13 |
July 20, 2014, 19:33 |
Rep Power: 144 |
Look up expert parameters in the documentation.
