July 9, 2014, 08:00 |
CFD Post Result Scalling
abdul
Rep Power: 12 |
I'm trying to simulate a large geometry (Airflow around and in a 6 storey building) and to simplify things I scaled down the geometry 1 to 10 before running the simulation, I also scaled down the boundary conditions with the same scale. However, Now that I've got my results, How do i scale back the value? Namly, The value on the Legend. I've tried to copy the solution Variables (Pressure, Velocity) and creating an expression for that but I've failed, Is there any other way? Also, Is my methodology correct for such situations? Thanks you! |
July 9, 2014, 08:18 |
Rep Power: 144 |
You scale physical models because it is difficult to fit a 6 storey building in a wind tunnel. When you do this you choose a non-dimensional parameter you are going to keep constant (probably Reynolds Number in your case), and the other relevant non-dimensional numbers change (maybe Froude or Mach number, maybe some heat transfer numbers). So when you scale you loose accuracy as you cannot scale and keep all non-dimensional numbers fixed.
The advantage of CFD is you can run the thing at full scale just as easily as at part scale. So you might as well model it full scale and not use any non-dimensional number scaling. This means all physical parameters are being correctly modelled with no approximation. So, in your case I recommend: 1) If you did not keep the Reynolds Number constant then your simulation results are rubbish and you are going to have to do them again anyway. You cannot simply scale it to the correct answer. 2) When you redo it model it at the full scale as part scale is no benefit in CFD. |
cfd post, cfx, large geometry, scale |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 10:26 |
Collect transient results CFD POST | mortain | CFX | 15 | April 17, 2015 09:29 |
View results at a contact region in CFD post | AGP | FLUENT | 0 | June 10, 2014 12:11 |
deviation in calculated force between CFX solver and CFD post | murx | CFX | 2 | April 9, 2014 21:03 |
User CEL Function and CFD Post | chastain | CFX | 4 | September 24, 2013 14:58 |
