Split Mass Flow Rate in ANSYS CFX
Old   June 30, 2014, 21:10
Question Split Mass Flow Rate in ANSYS CFX
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear all,
I am modelling blood flow in a bifurcated artery. I know the total inlet mass flow rate and fraction of the flow leaving each outlet. For example inlet mass flow is 0.9 gr/s and 20% of this flow passes through the outlet 1 and 80% leaves through the outlet 2.
For boundary condition, I used mass flow rate at inlet and both outlets; however, while solving the following notice is given for both outlets:
A wall has been placed at portion(s) of an OUTLET |
| boundary condition (at 100% of the faces, 100% of the area) |
| to prevent fluid from flowing into the domain. |
| The boundary condition name is: Outlet 1.
I know in this case I should use opening boundary condition, but the only known parameter at the outlets is mass flow rate fraction.
Please can anyone let me know how I should specify the boundary condition for my problem.
Thanks
AshtonJ
ashtonJ is offline   Reply With Quote
Old   July 2, 2014, 23:23
Erik
evcelica is on a distinguished road
First off, I would try a pressure boundary condition at your inlet. If you are gettng recirculation, extend your outlets further downstream.
evcelica is offline   Reply With Quote
Old   July 9, 2014, 04:08
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
You can try opening with reference pressure - if you know pressure on the BCs
Martin_Sz is offline   Reply With Quote
Mass flow rate of phase in post mat_cfd CFX 0 September 3, 2013 08:55
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 14:14
how to set BC for compressible flow target mass flow rate foolboy007 FLUENT 1 April 4, 2012 04:24
mass flow rate (CFX post) sanchezz CFX 2 January 14, 2010 07:54
mass flow rate on the Iso-clip surface & interior Sunil Gupta FLUENT 0 April 22, 2008 10:29
