Appropriate mesh for resolving noise frequency |
June 29, 2014, 15:18 |
Henry Arrigo
Rep Power: 16 |
Hi
Is there any equivalent option in CFX to what is known as the "Mesh Frequency Cut-off" option in Star-CCM+? If not, how is it possible to get sure that a CFX mesh can resolve target frequencies? |
June 29, 2014, 20:34 |
Rep Power: 144 |
I do not know what Mesh frequency cut off in Star is. Can you please explain it?
June 30, 2014, 08:00 |
Henry Arrigo
Rep Power: 16 |
"The mesh frequency cutoff scalar function can be used to qualify the suitability of the mesh ahead of a transient calculation by analyzing the frequency that the mesh can resolve. This analysis determines where and by how much to refine the mesh to capture up to the desired frequency. If, for example, the function value shows 1 kHz and you want to resolve up to 2 kHz, then refine the mesh by a factor of two."
June 30, 2014, 09:44 |
Rep Power: 144 |
CFX does not have anything like this built in. If you know the maths which defines the function then you can probably generate it as a user variable.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
Low Mesh Frequency Cutoff | fardinkhalili | STAR-CCM+ | 1 | March 19, 2014 15:20 |
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh | eddyy19g | ANSYS Meshing & Geometry | 3 | February 13, 2014 10:36 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
