cfx solve error and stop solve and fail solve |
June 24, 2014, 05:01 |
mahdi
Rep Power: 12 |
hi
my domain is a quarter of the original geometry of supersonic wind tunnel.wind tunnel mach number is 1.8 . in my domain Using tow symmetry boundary conditions and tow wall boundary condition and a boundary condition input and an output boundary condition my simulation cfx Boundary conditions is: ANALYSIS TYPE: Option = Steady State TURBULENCE MODEL: Option = k epsilon BOUNDARY: inlet FLOW REGIME: Option = Subsonic END HEAT TRANSFER: Option = Static Temperature Static Temperature = 300 [K] END MASS AND MOMENTUM: Option = Total Pressure Relative Pressure = 1.8 [bar] TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END BOUNDARY: outlet Boundary Type = OPENING Location = outlet FLOW REGIME: Option = Subsonic END HEAT TRANSFER: Opening Temperature = 300 [K] Option = Opening Temperature END MASS AND MOMENTUM: Option = Opening Pressure and Direction Relative Pressure = 84000 [Pa] END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END wall HEAT TRANSFER: Option = Adiabatic END MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END After 1600 itration cfx solver stop solution . The error is in the attached image: Please Help me, please Thanks for all |
June 24, 2014, 20:10 |
Rep Power: 144 |
June 27, 2014, 02:29 |
Marcin
Rep Power: 13 |
try to change the turbulence model to sst.
If this doesnt work try to change opening to an outlet with static pressure. |
July 3, 2014, 02:55 |
mahdi
Rep Power: 12 |
help me .help me
July 3, 2014, 03:01 |
Rep Power: 144 |
We already have. If you do not respond to the suggestions already here then we are not going to bother suggesting anything else.
cfx solver error |
