Y pipe flow simulation
Old   June 22, 2014, 11:54
Question Y pipe flow simulation
Vip
iv1985 is on a distinguished road
Hello:
I have run several simulations using a single inlet single outlet type geometry. I am trying to simulate a dual inlet single out "Y" shaped pipe and am not sure how to apply boundary conditions within CFX. Just wondering if someone has experience doing this. I am primarily interested in flow contours and determine pressure drop across the system.
iv1985 is offline   Reply With Quote
Old   June 22, 2014, 19:53
The concept is simple - you can only apply boundary conditions at locations where you can describe the flow conditions. So if you know the pressure or flow rate at your inlet boundary locations then use the appropriate boundary condition. If you do not know anything then you cannot define a boundary condition there.
Old   June 24, 2014, 02:35
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
When You click on the default domain (right button mouse) you can define boundary conditions like inlets and outlet
Martin_Sz is offline   Reply With Quote
inlets, pressure drop
Periodic Pipe Flow LES dvolkind CFX 8 March 21, 2020 06:30
Blockage in pipe ( using solidwork flow simulation) jchow FloEFD, FloWorks & FloTHERM 1 January 16, 2012 17:03
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
FDTD Simulation of flow through tapered pipe Jim Main CFD Forum 3 December 25, 2006 11:56
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 05:04
