June 20, 2014, 04:14 |
Ansys CFX Post
Christoph
Rep Power: 12 |
I have a radial compressor with inlet,diffusor and volute, and made planes in CFD Post with different radius=const. so long no problem, now i want to unwind the planes, so that i can see die whole plane with radius=const, with circumference over die height of the plane or conversely, that i can see the plane as a plate. Thank you for help. Ckern |
June 21, 2014, 07:01 |
Rep Power: 144 |
I do not think CFD-Post can do this. I would export the data in the plane and take it into tecplot, paraview or some other post pocessing package and do it there.
June 30, 2014, 09:34 |
Thomas
Rep Power: 12 |
Hi Christoph,
you should try the Turbo-mode. It is possible to do this there - the only problem is the definition of hub and shroud areas but it is possible and I did that already for a similar problem. |
Setting the desired Zoom level in ANSYS CFD Post for custom reports | shreyasr | CFX | 1 | July 11, 2013 02:57 |
Two way FSI post processing in CFX | ashli217 | ANSYS | 0 | May 3, 2013 06:43 |
Ansys CFX Post Processing | rajeshfromindia | CFX | 0 | February 19, 2013 12:21 |
ANSYS Multi-physics and CFX coupling error | anujit | CFX | 3 | June 21, 2009 19:39 |
ANSYS CFX POST State file | Mechstud | CFX | 1 | June 22, 2007 15:59 |
