Building an aortic valve using Immersed Solid method
Old   June 11, 2014, 10:52
Default Building an aortic valve using Immersed Solid method
TheForumLord is on a distinguished road
Dear experts,
While searching for a method that will allow me to capture the motion of aortic valves in Ansys, I encountered the name immersed solid method in cfx and was wondering-
Does someone know of a good tutorial about this method?
Does someone know of a good tutorial that teach how to model a moving valve that is also able to close properly?
thanks in advance
TheForumLord is offline   Reply With Quote
Old   June 11, 2014, 19:47
The CFX tutorials include an immersed solid example.
From memory immersed solids do not work well if the solid contacts another solid or a wall. This make it tricky to use them for closing valves.
Old   June 12, 2014, 02:25
[Hi ghorrocks,
How can I access the tutorials for CFX? WIll you please help me understand what is the difference between CFX and Fluent?
Thanks a lot for the advice !
QUOTE=ghorrocks;496675]The CFX tutorials include an immersed solid example.
From memory immersed solids do not work well if the solid contacts another solid or a wall. This make it tricky to use them for closing valves.[/QUOTE]
Old   June 12, 2014, 03:54
Have a look in the CFX help files for the examples.
The difference between CFX and Fluent is they are spelled differently.
aortic valve, blood flow, immersed solid
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 15:56
immersed boundary method of Markus Uhlmann dishengbin Main CFD Forum 5 May 9, 2012 06:44
Code for Immersed Boundary Method (ask for help) syq129 Main CFD Forum 2 November 23, 2010 04:16
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
Building solid cells kerem pekkan Siemens 0 November 21, 2000 18:47
