Mold Filling Simulation, Multiflow, Porous Media |
June 11, 2014, 09:43 |
rainer arenskrieger
Rep Power: 12 |
I am doing a molding simulation of a carbon fibre filled cavity that is filled with Resin. I want so simulate the filling process of a cavity. This cavity I filled with carbonfibre of a specific permeability. So I modeled a porous domain and a multiflow (Air and Resin) through this domain. As initial condition the cavity is filled with Air (100%) and through the inlet only Resin enters the cavity. I simulate with a transient simulation with total time=10s, timestep=0.1s and starting time=0s My Problem is: In post processing, when having a look volume fraction at the first time step the cavity is already to almost 90 filled with Resin. How is that possible? I inject Resin at 20g/s and my cavity is large enough to be not filled in a tenth of a second. The simulation takes place at ambient pressure. Thank you for your help EDIT: For some reason the Problem seems to be solved now although I only changed an insignificant parameter. Last edited by rainer_kit; June 11, 2014 at 10:59. Reason: Problem solved |
February 6, 2015, 03:39 |
Samuele Z
Rep Power: 19 |
Do you think it's possible to do the same using OpenFOAM?
February 6, 2015, 04:45 |
Rep Power: 144 |
No idea. This is the CFX forum. Try the openfoam forum.
multiflow, porous media, resin transfer molding |
transient Simulation with porous media | Chrisi1984 | OpenFOAM Running, Solving & CFD | 6 | August 26, 2015 17:13 |
Solid Properties Setup In Simulation of Porous Media | Modest Cat | FLUENT | 4 | March 26, 2012 06:00 |
Benchmark for porous media simulation | siw | Main CFD Forum | 4 | February 7, 2012 15:14 |
asking help for porous media simulation | jim23keda | FLUENT | 0 | July 29, 2010 10:21 |
Tube bundle simulation using porous media | Jitendra | Main CFD Forum | 2 | April 13, 2004 08:57 |
