Most appropriate interface type CFX_Pre
Old   June 10, 2014, 15:29
Default Most appropriate interface type CFX_Pre
Vasilis
vzooz is on a distinguished road
Hi guys,
I have to model a fluid flow which is forced to pass through a wedge.
The upper boundary is supposed to be a "rotor" and it is horizontal.
The lower boundary is a stator and has an inclination in order to converge to the rotor's surface. The flow (lubricant) which passes through that geometry, is defined by a rotational speed around a global axis at the stator-fluid interface.
I am not sure which interface type fits best for the fluid-rotor interface.
I have tried so far the "general connection" (i use this for the fluid-stator interface) and the "rotational periodicity" which both give similar results but the differences for critical values are large enough to be ignored (~5%). Analysis type is steady state.
Thanks in advance
vzooz is offline   Reply With Quote
Old   June 10, 2014, 20:01
Please post an image of what you are modelling.
general connection, interfaces, rotational, translational periodicity
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 09:07
multiphaseInterFoam: timestep error by simulating a co-extrusion nozzle Quatschinsky OpenFOAM Running, Solving & CFD 7 March 27, 2014 06:08
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
