May 31, 2014, 01:40 |
some help in my simulation, vent silencer
Greydil
Rep Power: 12 |
hi! first of all i am new in this forum i have been reading some threads for a long time before posting this thread. i hipe you guys can help me out with my simulation in CFX...
I am student and i am doing my thesis and i need to use cfx to predict if my silencer works or not. i designed a silencer, i already meshed my geometry got several elements around 8 millions. i finally got convergence i want to shere with you if my results are ok because its my first simulation in cfx, i have already done some workshops, and my convergence graph is a litlle different to the workshops. i dont know how to set up steam or superheated steam , i run this with water at 280c. prior to all i am verifying my geometric convergence so my fluid for the moment doesnt matter ( that was said by my tutor).. please i hope you can helpme thanks!!! i attached my txt file and the picture of my graph. [IMG][/IMG] sorry for my bad english |
May 31, 2014, 07:24 |
Rep Power: 144 |
Have you read the FAQ on this? http://www.cfd-online.com/Wiki/Ansys...gence_criteria
May 31, 2014, 16:23 |
Greydil
Rep Power: 12 |
thanks, for your fast reply...
did my run converge? what do you think? i think my mesh is ok i have 8M elements, should i need to refine it more? i dont know what to look if is convergin. sorry i have learned ansys through internet and some workshops, as you all probably know workshops always works. Pd. thanks |
June 1, 2014, 03:50 |
Rep Power: 144 |
Did it converge? Almost certainly not.
Is your mesk OK? New people to CFD make major mistakes in meshing about 95% of the time. So it almost certainly needs work as well. Read the documentation on obtaining convergence for a start on convergence. |
June 8, 2014, 22:04 |
Greydil
Rep Power: 12 |
hi i modified my mesh an create in this link a document with all the things i am doing, i hope you guys check it and see what i am doing wrong, and thanks for answering back.
https://www.dropbox.com/s/zefwb41y0p...0all%20CFD.pdf |
June 9, 2014, 20:14 |
Rep Power: 144 |
First of all, the CCL file (or output file) contains everything necessary about the solver in a text format. No need to copy images of CFX-Pre into a document. Attach that in future.
Secondly, I would run this with a coarse mesh to start with, and only after it is running reliably would I consider refining the mesh. Third - This model appears to have symmetry. If so you might as well make use of it and halve your simulation size. |
June 10, 2014, 12:12 |
Greydil
Rep Power: 12 |
Thanks for taking the time to answer back, next time I'll just upload de output file sorry for that, I though it might be easier for you to look and see where my problem is.
I'll try a coarser mesh, but first is water ideal gas the right fluid material for my simulation? What else do you think I should modify besides a coarser mesh? Thanks and sorry. |
June 10, 2014, 19:56 |
Rep Power: 144 |
The coarser mesh is for development only. You will need a fine mesh as soon as it works reliably to get accurate answers.
What material properties - what Mach number is the flow in this device? What pressure or temperature differences? And phase change? |
July 10, 2014, 00:47 |
#9 |
Greydil
Rep Power: 12 |
hi! it finally converged.... my problems were on my boundary conditions. i just put in the inlet and static pressure at the outlet...
I am now facing another problem my run converged using upwind advection sheme. A friedn told me that if i want to be sure about it i can run again using my upwind results and do a high res..... when i do this, it doesnt onverged, what do you suggest me!!!? thanks |
July 10, 2014, 01:48 |
#10 |
Rep Power: 144 |
Have you read the FAQ I linked to on post #2? It covers all that - see points 3-5.
July 15, 2014, 20:47 |
#11 |
Greydil
Rep Power: 12 |
hi, again.. i solved my problem it seem that i cant use high res because my model is to complex and my machine isnt enough so it would take ages to run and in my country we have electricity issues so i just made last run with 0.75 in blend Factor..
Now i am facing a problem i hope you can help me, i need to do a accoustic analisis, i just want to know how many Db are lost with my silencer, i was trying Harmonic response but i found it TOO much complicated because all the commands, so do you think another way to do what i want? Thanks. Bless |
July 15, 2014, 20:51 |
#12 |
Rep Power: 144 |
In CFX the only way is to run it and monitor the pressure at a point far away and the calculate the sound intensity from the pressure wave. The put your silencer in it and re-run it to get another sound level.
July 16, 2014, 01:00 |
#13 |
Greydil
Rep Power: 12 |
thanks glenn, how exactly? i dont get it..sorry.
Do i need to monitor a point far away fron the outlet of my silencer? and then put my silencer in that point? Thanks once again |
July 16, 2014, 07:34 |
#14 |
Rep Power: 144 |
First of all - if you do not know about acoustics and CFD then you are never going to complete this simulation. Make sure you understand how to do an accurate CFD study and you understand how acoustics work.
Then do a compressible flow simulation with your gizmo in the middle of the domain and your monitor point somewhere far away to represent far field results. You will need to put the outer boundary of the domain much further out. |
steam vent silencer |
Huge file sizes when Running VOF simulation | aarratia | FLUENT | 0 | May 8, 2014 13:27 |
Supersonic Nozzle Exhaust Simulation | mikeh | FLUENT | 0 | May 1, 2014 22:28 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 11:44 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 09:18 |
Please HELP (Smoke simulation) | Amr | FLUENT | 0 | February 25, 2006 20:38 |
