May 20, 2014, 22:36 |
Three-phase bubble column problem
Filipe de Menezes
Rep Power: 14 |
Hi Everybody,
I am trying to simulate a three-fluid model (water, air and oil above). First I tried the case only with water and air and I had good results. However, when I inserted the oil above the water it was not phisically valid, with the volume of oil continuously increasing even using degassing condition. Can someone please help on this? Thanks in advance, Filipe. |
May 21, 2014, 08:32 |
Rep Power: 144 |
Please post an image of what you are modelling and the CCL.
May 21, 2014, 18:16 |
Filipe de Menezes
Rep Power: 14 |
The files are attached!
The two-phase image is physically correct, but the three-phase not (0s, 2s and 6s are represented). Thanks for the patience! three-phase 0s oil VOF.jpg two-phase.jpg three-phase 2s oil VOF.jpg three-phase 6s oil VOF.jpg panela.txt |
May 21, 2014, 19:43 |
Rep Power: 144 |
Are you sure you are adequately converged?
May 21, 2014, 20:40 |
Filipe de Menezes
Rep Power: 14 |
I think so.. Do you think it could be a convergence problem?
bubble column, fluids, multiphase, three-phase, water air and oil |
Bubble column simulation with Lift coefficient UDF | raju.vadlakonda | Fluent UDF and Scheme Programming | 8 | June 19, 2023 09:36 |
bubble column | ken | FLUENT | 1 | June 30, 2013 02:18 |
bubble column reactor | hossein65 | Main CFD Forum | 0 | June 25, 2013 16:33 |
Modelling a Water-Air bubble column | GerhardHolzinger | OpenFOAM Running, Solving & CFD | 1 | February 28, 2012 05:12 |
liquid decreases in bubble column E-E simulation | jhchen | ANSYS | 1 | August 3, 2010 11:49 |
