FSI of a shell
Old   May 11, 2014, 17:48
Default FSI of a shell
Henry Arrigo
Henry Arrigo is on a distinguished road
Hello all,
I want to conduct a FSI simulation which is involved the vibration of a rectangular shell metal. I have to apply zero moment and zero displacements BCs on shell edges, so it seems that it has to be modeled by a surface (since moments boundary conditions are only applicable to lines). Since a shell is of zero thickness and in FSI simulations solid region should be subtracted from fluid domain, I get confused how to subtract a surface (which represents the shell) from the fluid domain. Now my questions are:
1. is this procedure correct?
2. if yes, how can I do that?
thanks
Henry Arrigo is offline   Reply With Quote
Old   May 12, 2014, 17:12
stumpy is on a distinguished road
Yes, you can do this.
The structure should use a surface with shells as you have described.
The fluid geometry/mesh is the same as when using a thin wall in a CFD case. You need two solid bodies (but 1 part). The surface where the two solids meet is the thin wall. In CFX you'll have two wall boundary conditions; both of these can connect to the same FSI region from Mechanical.
stumpy is offline   Reply With Quote
Old   May 12, 2014, 18:15
Henry Arrigo
Thank you Stumpy,
Is there any special treatment for modeling thin walls in CFX?
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 05:14
fsi sun Siemens 8 January 20, 2009 00:17
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
FSI for shell element Edison CFX 0 December 21, 2007 01:58
