Problem with streamlines in an axial turbine. |
May 8, 2014, 10:58 |
Simon
Rep Power: 12 |
Hey CFXlers,
i´ve got some problems with streamlines in CFX-Post. In the application is an interface with nonoverlapping surfaces. In the discription for GGI´s and nonoverlapping surfaces is written that CFX creates a "no slip wall". In the first pic you see an application where a wall have been createt by myself. In the second picture CFX has to create a wall, but the streamlines are going wrong. The big mesh is rotating and the small mesh is stationary. 1.jpg 2.jpg Can anybody explaine what was happend? Thx |
May 8, 2014, 19:16 |
Rep Power: 144 |
Check which element faces have been determined to be part of the interface. It might have missed some in the interface region. Can you post an image of the mesh on the interface?
May 9, 2014, 05:47 |
Simon
Rep Power: 12 |
This is only a test application for my application, an axial turbine. Cause there I´ve got the same problem. Maybe there is a problem with some default setting in CFX?
Pic 1. first side of the interface Pic 2. second side of the interface 1.jpg 2.jpg I think it looks normal. It´s frozen rotor. Thank you!! |
May 9, 2014, 07:40 |
Rep Power: 144 |
Is it well converged?
Have you plotted velocity in stn frame? |
May 9, 2014, 07:45 |
Simon
Rep Power: 12 |
Yes, it coverged well.
It doesen´t matter if I plot velocity or velority str frame. The solution looks the same. |
May 10, 2014, 09:14 |
Rep Power: 144 |
Have you tried the "Alternate rotation model"?
May 14, 2014, 04:44 |
Simon
Rep Power: 12 |
Yes,
it looks the same. |
Problem with torque output from a turbine simulation. | pa-dundas | FLUENT | 5 | July 17, 2022 06:27 |
CFD_screening problem for Francis Turbine Optimization | berk can | Fidelity CFD | 3 | February 22, 2014 13:08 |
Surface streamlines on axial flow fans | Jennifer | CFX | 2 | February 17, 2009 15:50 |
Test Cases for Axial Flow Turbine | shraman | Main CFD Forum | 0 | July 25, 2006 05:43 |
