Modeling of a channel flow with water and air |
Rep Power: 16 ![]() |
I have a good understanding of CFD and have worked with ANSYS CFX for quite some time now, but to this point I only dealt with air and wind engineering problems. Now, I wanna simulate the flow of a river over an obstacle and I can not figure out how I can set my Inlet to have both: Water at the bottom of the domain with a given height and air above the water of course. Any help is highly appreciated, thanks in advance! |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Have a look at the tutorial example: free surface flow over a bump. It does exactly what you ask.
Thank you very much. I tried the tutorial for my geometry and the solver is running right now. The only problem is that I get and error that air and water is flowing into my domain at the outlet although it shouldnt in a physical sense.
Maybe someone else has the same problem: I found the solution by adjusting the horizontal and vertical component of the coordinate system. In the tutorial y is the vertical axis.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Gravitational water flow in closed channel. | Szymon85 | CFX | 7 | September 3, 2013 16:28 |
Mass Flow rate in spray water modeling | Behnam Ghadimi | FLUENT | 0 | June 8, 2013 16:05 |
Mass Flow rate in spray water modeling | Behnam Ghadimi | Main CFD Forum | 0 | June 8, 2013 15:48 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
