Problems of VOF model simulating temperature stratified reservoir
Old   May 6, 2014, 22:15
Default Problems of VOF model simulating temperature stratified reservoir
Betta Hwang
Betta is on a distinguished road
Hey there,
I am modeling a thermal stratified reservoir, and simplify the temperature structure as two-layer, say layer 1 is 23 ^{\circ}C and layer 2 is 20 ^{\circ}C.
The geometry model is simple, just a tank with an outlet in the end wall. And I was stuck by how to set the pressure at the inlet(outlet flow rate is known). the flow is supposed as stable.
I tried the VOF model, and I cannot figure out how to get the flow rates of the two layers.
Thank you very much.
Betta is offline   Reply With Quote
Old   May 7, 2014, 08:19
Please post an image of what you are modelling.
Old   May 7, 2014, 10:59
Betta Hwang
Sure.
Thank you to comment.
As shown in the figure, it is a simple tank(can be seen as large reservoir too) with an outlet. I was wondering how can I set inlet pressure B.C(maybe other B.C., I've no idea). for two-layer flow (temperature difference) if I know the outflow rate through the outlet.
And another problem:
Can I use the VOF model provided by CFX to simulate the two layer? I tried in this way but I cannot get the flow rates of the two layers respectively. I used that 'Fluid1.massflow@outlet' or something like this and the warning came out say there was no such thing. So what is wrong with my settings?
Any suggestion will be appreciated.
Thank you all.
Old   May 7, 2014, 19:41
The free surface multiphase model is used when you have multiple phases (ie gas and liquid). If you have a single phase at different temperatures then just use a thermal model.
Set the temperature at the inlet/opening to a 1D interpolation function or a CEL expression which varies the temperature as a function of height. Simple.
Old   May 7, 2014, 21:51
Betta Hwang
Many thanks.
If I set the inlet temperature using CEL, say using STEP function, what the pressure then?
And also the reference density and/or temperature bother me.
Any suggestion about this. Thank you so much for your help.
Old   May 8, 2014, 00:10
What pressure are you trying to model? If it is open to atmosphere then just zero relative pressure. If it has a flow applied (I suspect it does to generate the thermal stratification you describe) then you need to model a larger volume to model this stratification.
Old   May 9, 2014, 05:14
Betta Hwang
thanks a lot for your help and comments.
I will try it again.
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
urgent... multiphase cfd model of packed bed reactor.( VOF MODEL using) balu@gold6 FLUENT 4 July 26, 2012 11:37
question about Heat transfer between two phases with VOF model sooroo3 FLUENT 0 February 15, 2011 04:24
Heterogeneous reaction between phases with VOF model sooroo3 Fluent UDF and Scheme Programming 0 February 15, 2011 03:59
about VOF model rey FLUENT 5 August 13, 2002 07:02
