April 26, 2014, 11:19 |
Heat Exchanger
Daniel Frederik
Rep Power: 12 |
Hi everybody
I'm modelling an heat exchanger in form of two tubes, one Inside the other with opposite massflow. I have only two fluide domaines. I have not modeled the solid part of the tube. is there a way to define in the interface the thermal resistance of the tube without having to model it? I work with symmetries so I designed only a fourth like visible in the picture. Thank you in advance |
April 26, 2014, 11:40 |
Thiagu
Rep Power: 14 |
CFX V14.5 has option to define thin solids or add thermal resistance between interfaces. While defining interface check in " Additional Interface Models tab"
April 26, 2014, 11:51 |
Daniel Frederik
Rep Power: 12 |
Thank you very much, i succeded!
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 04:28 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Macro Heat Exchanger not selecting (Please help!) | zdeth | FLUENT | 2 | September 11, 2012 13:52 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
