Heat transfer, mass fraction residual problem |
April 23, 2014, 05:20 |
Heat transfer, mass fraction residual problem in coal combustion
Jinwhan Ryuk
Rep Power: 13 |
During coal combustion steady state analysis, I meet convergence problems in heat transfer and mass fraction. Momentum and mass, turbulence, and particle source change rates satisfy default residuals. And monitoring point also shows steady state characteristic well. How can I improve convergence in heat transfer and mass fractions? I tried timescal change in mass fraction as autotime scale and physical timescale but it didn't help. Fuel Gas and H2O RMS Mass Fraction especially show bad residual plot 1.0E-3<residual<1.0E-2 and almost constant lines. Thank you for reading my problem.
April 23, 2014, 07:18 |
Rep Power: 144 |
You have to expect convergence difficulties in combustion modelling, especially for the heat equation and/or combustion reactants.
First of all, have a look at the residuals in the post processor. You might need to add the residuals to the results file to do this. Have a look at where the maximum residuals occur - is it at an area of importance to the flow? Also consider whether your convergence is tight enough, even though it has not reached your default convergence tolerance. Do a sensitivity study and see if you need tight convergence or not. |
May 15, 2014, 04:17 |
Particle emissivity problem
Jinwhan Ryuk
Rep Power: 13 |
Thank you very much indeed ghorrocks. Due to your help my work has developed quite a lot. I want to ask another thing related to coal particle emissivity setting in CFX. I found some papers dealing with particle emissivity. It changes with furnace temperature. So, I put it as temperature function but CFX says 'Only CONSTANT emissivity is supported for particle materials.' Do you have any advice for helping me again? As you know coal particle emissivity affects a lot of combustion calculation and residuals.
May 15, 2014, 07:24 |
Rep Power: 144 |
I did not know that actually. I don't work in the field of coal combustion - but I can see how it has an effect.
First of all I would do a quick sensitivity test - run a high and low emissivity and see if it does make a difference. If it makes no difference then it does not matter. You could also try setting the emissivity at the average temperature of the furnace, that might be close enough. There are ways around the emissivity as a function of stuff restriction but better check the basic stuff first. |
May 19, 2014, 06:28 |
I am trying to do this.
Jinwhan Ryuk
Rep Power: 13 |
As you said, I am trying to do the sensitivity test. As I told you, emissivity takes a lot of effect of convergence and calculation results in coal combustion problem. Thank you very much for your help. It is almost impossible to solve the problem properly without proper boundary conditions like coal combustion tutorial.
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 17:12 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
Extremely slow simulation with interDyMFoam | jrrygg | OpenFOAM Running, Solving & CFD | 9 | April 23, 2013 11:14 |
pisoFoam - unstable pressure residual | Industrial_CFD | OpenFOAM Running, Solving & CFD | 21 | February 24, 2013 16:39 |
