Saima
Rep Power: 16 ![]() |
Hello Guys,
I am doing flow analysis of a blade in CFX and wanted to plot Mach contour and velocity profile on blade surface in span wise direction. Guide me how to do that in CFX post processing? Regards,
Best Redards, Saima |
Rep Power: 143 ![]() ![]() ![]() ![]() |
Of course the velocity is zero on the blade surface, and so is the Mach number due to the no slip condition. Can you explain what you are trying to do better?
Saima
I have created a user surface by offsetting the blade a mm on CFX-post. Then I am able to draw Mach contours.
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 06:21 |
CFX Post processing | maryamprana | CFX | 0 | January 18, 2013 11:58 |
[OpenFOAM] is parallel processing available in parafoam for post processing? | sachinlb | ParaView | 1 | August 14, 2012 09:52 |
CFX Post export problem | jeff_F | CFX | 0 | August 17, 2009 21:25 |
Proper output of angle of attack in CFX post | Kevin | CFX | 3 | October 18, 2006 12:18 |
