enclosed circulating flow
Old   April 10, 2014, 05:50
Default enclosed circulating flow
keeper is on a distinguished road
Hello all.
I have a question about simulating water flow inside enclosed system. The water goes from the tank through the pipes and goes back.
But I don't know how to set up BCs for inlet/outlet. Where to put them to have fluent circulating flow?
Thank you for your suggestions.
Regards
keeper is offline   Reply With Quote
Old   April 10, 2014, 07:29
Try the fluent forum. This is the CFX forum.
But your question does not seem to be specific to a CFD solver. Your question would apply just as well to any CFD solver.
You have to think of the real system. The flow will not move unless something moves it. Is there a pump? Is an area heated? Is there inertia left over from previous flow? In all these cases you simply model the thing which is making the flow move. You would model all of these situations differently.
Old   April 10, 2014, 07:55
Sorry ghorrocks I meant to make the flow fluetly going yes there is a pump. So I just have to move with the pump and I don't have to specify any in/out BC?
thank you for your answer.
Old   April 10, 2014, 08:11
If there is a pump then model the pump. I presume you do not want to model the detail of the pump - so generally that means use a momentum source term to move the flow, with the source term set up to provide the same power to the fluid as the pump does.
Have a look in the documentation for how to set up source terms.
Old   April 10, 2014, 08:19
yes you are right I don't want to model it. perfect, thanks a lot
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 06:58
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 10:49
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 06:57
