Pick a Node in cfd post
Old   April 9, 2014, 23:34
Default Pick a Node in cfd post
newbie384 is on a distinguished road
Hi
I would like to create points on a rotating blade surface so that I can export the pressure at those points as the blade rotating. I found that if I create points by giving the XYZ coordinates, the points will be fixed in position and they do not move together with the rotating blade surface. (Please correct me if I am wrong)
In order to let the points move together with the rotating blade, I think I have to create points by specifying node number. How can I pick a node in CFD Post? I tried probe but it gives me faulty location.
Thank you in advance.
newbie384 is offline   Reply With Quote
Old   April 10, 2014, 03:31
When I go Location/Point I see Definition/Method, with options XYZ, Node Number and a few other options. So that is what you are looking for isn't it?
Old   April 10, 2014, 08:25
I want to define a point by using the node number. However, in order to do that, I need to know the node number before that. My question is, how can I know the node number? I know that some software allow the users to pick a node by mouse, and then it will display the node number. How can I achieve the same thing in CFD Post?
Old   March 2, 2017, 07:24
Johannes Hall
yonpanman is on a distinguished road
Hello there,
Did you happen to find an answer to you question?
Regards
yonpanman is offline   Reply With Quote
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 20, 2015 00:40
Collect transient results CFD POST mortain CFX 15 April 17, 2015 09:29
deviation in calculated force between CFX solver and CFD post murx CFX 2 April 9, 2014 21:03
User CEL Function and CFD Post chastain CFX 4 September 24, 2013 14:58
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 UDS_rambler FLUENT 2 November 22, 2011 10:46
