analyzing the temperature of fliud (air) flow inside an underground duct. |
March 30, 2014, 15:46 |
hello everybody, this is arshbunny. i am doing my project on air conditioning of a room using underground duct. i want to analyze the flow of air inside the underground duct. all know that the underground duct is at lower temperature than the atmospheric one in summers. the air enters the duct at 40 C, the temperature of the duct surface is 25 C, as the air will pass through the duct, due to convection heat transfer, it will get cooled up and provide the effect of air conditioning.
i have watched all cfx tutorials, conjugate heat transfer tutorials and almost near to the completion of the analysis. but i am unable to do two things:- 1.) i have analyzed the streamlines(velocity) and other contours, but i am unable to analyze the temeperature changes in the air streamlines as it travels inside the duct. this may be due to the fact that i havent inserted any expression, as i dont know how to insert an expression in cfx-pre. |
March 30, 2014, 19:07 |
Rep Power: 144 |
No need for any expressions. You will not see a temperature change by looking at streamlines. Have you tried looking at the temperature?
March 31, 2014, 09:41 |
yes i tried everything to see temperature change in the fluid...but it doesnt show
March 31, 2014, 18:48 |
Rep Power: 144 |
Have you done the tutorial examples? This is basic post processing and is demonstrated in several tutorial examples.
April 1, 2014, 00:42 |
Rep Power: 18 |
April 1, 2014, 05:20 |
need help
#6 | |
Deldan Namgial
Rep Power: 12 |
April 1, 2014, 14:54 |
yes, i saw temperature variations at the "outlet" boundary of the "fluid" domain, but it shows weird values. at inlet, the air temp is 40 C and i expect it to reach 25 C at the outlet, but it shows the variation in -10 to -50 C. i think i am wrong in applying boundary conditions on the "solid" domain
April 1, 2014, 15:39 |
#8 | |
April 1, 2014, 19:38 |
#9 |
Rep Power: 144 |
arshbunny: Please post the CCL of what you are modelling, and the output file too if possible.
Deldan: Please start a new thread for a new question. Do not hijack existing threads. |
April 3, 2014, 09:52 |
#10 |
Deldan Namgial
Rep Power: 12 |
ok so sorry for hijacking present thread
ansys 14 cfx, cfx & air content, cfx pre, expression |
Coupled DPM water spray inside enclosed volume of air | dan86 | FLUENT | 0 | July 19, 2013 12:23 |
Some questions about flow field inside an oven | Hao Yu | Main CFD Forum | 8 | July 27, 2000 15:04 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
Duct Flow | omar | Main CFD Forum | 4 | December 9, 1999 13:43 |
HELP!!! Indoor air flow pattern | Peter Zhang | Main CFD Forum | 4 | November 3, 1999 03:49 |
