specific heat capacity at constant pressure in CFD Post
Old   March 21, 2014, 23:24
Default specific heat capacity at constant pressure in CFD Post
newbie384 is on a distinguished road
I know that I can see the value of specific heat capacity at constant pressure under material in cfx pre. How can I use the value to create a variable in CFD post? For example, static enthalpy=specific heat capacity at constant pressure * static temperature.
I just could not find it in cfd post. what I did is to assign the value of specific heat capacity at constant pressure by myself in my variable. However, this will give me the wrong unit.
Thank you in advance.
newbie384 is offline   Reply With Quote
Old   March 21, 2014, 23:39
I think I found where to get it. Thanks anyway.
Old   November 26, 2015, 12:54
ghof
ghofrane is on a distinguished road
hi, please can you give to me how you calculat the specific heat in cfd post
because i need to see the variation of cp in diffrrete position in the pipe
thx
ghofrane is offline   Reply With Quote
Old   November 26, 2015, 16:34
If you have variable Cp then it should be available as a variable in the puzzlingly labeled "..." button. If not you will have to assign it to a additional variable set to a CEL value, rerun the simulation and then you will have access to it.
ghorrocks is online now   Reply With Quote
Old   November 27, 2015, 17:00
ghof
thank you very much for yr reply.
I have a cp as fonction of temperature and i solved it with udf in fluent but i can found it in CFD post, and i don't found also the thermal conductivity.
can you please explian me more how i can do it because this is the first that i work with CFD post and i don't really understand your answer.
thank you
Old   November 27, 2015, 22:25
If the simulation was done in Fluent I do not know what it does - this is the CFX forum. Try the fluent forum.
UDF for specific heat as function of pressure ghobold Fluent UDF and Scheme Programming 20 August 22, 2019 09:19
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Cn specific heat capacity changes with Temperatur? lightgas CFX 4 July 7, 2006 07:51
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
