March 16, 2014, 06:04 |
Axial Velocity Contour in non-planar bend
Omid
Rep Power: 14 |
Hi guys,
I simulated a fluid flow in a non-planar bend in which the inlet and outlet surfaces are not placed in the same plane. The bend consists of two 90 degree bends. I would like to see axial velocity in different sections along the pipe in CFS-Post. I could have seen total velocity contour, but my problem is in plotting axial velocity. The axial vector is not along coordinates, but I have the normal vector at each plane. Do you have any idea how to get axial velocity contour via CFD-Post? Thanks, Omid. |
March 16, 2014, 17:30 |
Rep Power: 144 |
You could define a local coordinate frame at each point to get the axial component.
August 4, 2014, 13:04 |
Ali reza
Rep Power: 12 |
hi guys
could you please explain more what I have to do to plot an axial contours in non planar 3D curved pipe in different sections? |
Axial Velocity Contour in non-planar bend | omidmd | FLUENT | 2 | October 7, 2014 14:22 |
How to draw velocity contours along the bend of U-pipe | mariam.sara | FLUENT | 1 | March 20, 2011 08:12 |
Axial velocity problem | clueless | Main CFD Forum | 0 | May 15, 2009 04:01 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
velocity profile in a 90 degrees bend | Tim | Main CFD Forum | 6 | June 18, 1999 02:58 |
