March 16, 2014, 02:57 |
Water diffusion into air
Mahmoud Gabr
Rep Power: 14 |
Dear experts;
I have a problem in modelling my first multiphase model. simply, it is a static water in a closed volume with air (volume fraction is 0.3 for liquid water and 0.7 for air), All volume walls have 80 C0 temperature. volume is closed so no inlet or outlet. The required is the volume fraction of water vapor due to diffusion (there is no boiling in this problem) in the steady state case and then it would be converted to transient case for calculating diffusion rate. I have tried to model it by define fluid phases as follow; Air , water and water vapor. I had selected homogeneous multiphase model with homogeneous heat transfer model. turbulence model is K-Epsilon and fluid pair model was defined for Air and liquid water phase for the interphase transfer is free surface. Also defined for air and water vapor as mixture. initialization condition for the volume fraction for each fluid was defined (air =0.3 water liquid =0.7 and water vapor =0) I had searched in ANSYS help for diffusion schemes in expert parameters but i didn't find enough data explaining each scheme so until now I didn't use any scheme in solving. Could someone suggest ideas for improving this model and give me links explaining diffusion schemes better as until now I have this like for explaining this schemes but it is also not enough [http://www.arc.vt.edu/ansys_help/cfx...SolvDisc.html]. Thanks |
March 16, 2014, 05:42 |
Rep Power: 144 |
You will have to describe what you are doing more thoroughly for us to help.
Is there a single air/water interface? Is the bottom 30% of the box filled with water and the top 70% filled with air? Does it have a distinct interface between the air and the water? Are there water droplets or air bubbles? Is the humidity of the air important? Is water evaporation important? |
March 16, 2014, 07:02 |
Mahmoud Gabr
Rep Power: 14 |
Thanks ghorrocks
following is answer for your questions Is there a single air/water interface? yes, water upper surface. Is the bottom 30% of the box filled with water and the top 70% filled with air? yes Does it have a distinct interface between the air and the water? condition for a simple interface between water and air. Is the humidity of the air important? Is water evaporation important? both yes, because I want to develop this model for determine the effectiveness of water desalination system in evaporating water and also water diffusion due to concentration into air. please let me know if there are more questions for clarifying my model. Regards |
March 16, 2014, 18:06 |
Rep Power: 144 |
So it appears you have a multiphase model (liquid water versus air), and the air is a multicomponent gas (air+water vapour). The water vapour in air is not a multiphase model as the water vapour is the same phase as the air.
The liquid water/air multiphase bit should be straight forward. A multicomponent gas is also straight forward. The tricky bit in this simulation is to get the conditions right on the interface so water evaporates (and condenses if necessary) at the correct rate and adds to the water vapour. But before you work on the evaporation on the interface do a multiphase model (water/air) and a multicomponent model (water vapour/air) first with no evaporation at the interface to make sure the basic stuff is working first. |
March 17, 2014, 00:30 |
Mahmoud Gabr
Rep Power: 14 |
So how can model this ghorrocks,
1- should I build 2 volumes one for water and another for air and make an interface between them? 2- if Yes ;How can I define fluid in a volume (domain) , and define another fluid in another domain because when I divided the total volume into 2 volume, I couldn't define one or more fluid for each one differ from the other volume. 3- what would be the interface type between the 2 volumes (assuming the first question answer is Yes) for modelling the evaporation and diffusion on water free surface. Regards |
March 17, 2014, 04:41 |
Rep Power: 144 |
Is the interface location fixed? Do you care about the flows in the water and the air?
March 17, 2014, 06:19 |
Mahmoud Gabr
Rep Power: 14 |
-when I had defined the interface, it was fixed related to named selected face . can I make it variable or imaginary, as the free surface of the water volume would not fixed while water vapor is evaporating from the water liquid into air.
-Yes I care about both flow in the water and the air Regards |
March 17, 2014, 17:25 |
Rep Power: 144 |
It is still not completely clear but I suspect a free surface multiphase model for the air/water interface will work, and multicomponent mixture for the air/water vapour.
So have a look at the CFX tutorials for setting up free surface simulations. It also has examples on multipcomponent mixtures. But combining them together you will have to work out yourself. |
March 17, 2014, 17:47 |
#9 |
Mahmoud Gabr
Rep Power: 14 |
Okay, but could you tell me how to define one or more fluid for a domain and another one fluid or more for another domain. I have tried many times for doing that and unfortunately couldn't also I have tried to find a tutorial for that and also couldn't.
March 17, 2014, 17:48 |
#10 |
Rep Power: 144 |
Your simulation is a single domain. Have a look at the flow over a bump tutorial for how to set up free surface multiphase simulations.
March 18, 2014, 17:17 |
#11 |
Mahmoud Gabr
Rep Power: 14 |
Thanks ghorrocks; I am looking at it right now
Regards |
April 14, 2014, 04:55 |
#12 |
Mahmoud Gabr
Rep Power: 14 |
Hi ghorrocks;
I have tried many tutorials and finally I can model 2 phase flow . Now I have a new problem in defining condensation of water vapor on low temperature vertical wall. could you help me in defining it correctly or give me a tutorial for this case. my case is closed volume (2D) , VOF , transient , water vapor at 400K and cold wall at 280K. no inlet or outlet just closed volume. Best regards |
April 14, 2014, 08:22 |
#13 |
Rep Power: 144 |
I do nto have any tutorials for the wall condensation model. Try the ANSYS community page as it might have one. Otherwise ANSYS support will have some I suspect, so get in contact with them.
April 14, 2014, 15:39 |
#14 |
Mahmoud Gabr
Rep Power: 14 |
Thanks ghorrocks for your guidance. I will try both of them. thank you
November 20, 2020, 00:12 |
Mr
#15 | |
jiangsu
Rep Power: 6 |
November 20, 2020, 00:40 |
#16 |
Rep Power: 144 |
CFX has many tutorial examples available which show how multiphase modelling is done. You can get them on the ANSYS Customer website, or the ANSYS Academic website depending on whether you are a commercial or academic customer.
There are also lots of CFX tutorials available on youtube and other sources on the web. They are not hard to find.
November 20, 2020, 02:35 |
#17 | |
jiangsu
Rep Power: 6 |
Yeah, I have visited and watched many tutorials on two-phase flow, but I haven't found exactly the flow explaining the air that is compressing water in pressure vessel. If you know exactly, kindly share the link with me. Thank you once again. |
September 3, 2023, 19:45 |
#18 | |
Gokhan Pulati
Rep Power: 4 |
September 3, 2023, 20:04 |
#19 |
Rep Power: 144 |
Questions about Fluent should be asked on the Fluent forum. If you are not getting any response there then have a think about why nobody is interested in responding and try again.
The way you apply these models is very different in CFX versus Fluent, so I will not be able to help you much.
September 3, 2023, 20:06 |
#20 | |
Gokhan Pulati
Rep Power: 4 |
diffusion-type, multiphase flow |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
I am NOT getting right pressure at the air inlet in water column | kcfd | FLUENT | 0 | November 25, 2012 00:14 |
Boiling of water with hot air | Dr. Flow Squad | CFX | 2 | July 27, 2009 08:37 |
Mass diffusion of surface exposed to water flow | Derek | FLUENT | 3 | February 27, 2006 15:38 |
VOF-compression of air with rising water | yavuz | FLUENT | 0 | November 26, 2005 10:00 |
