Mr CFD
Rep Power: 15 ![]() |
Has anyone used the BSL EARSM turbulence model with success in flows which involve adverse pressure gradients? It seems like a fantastic well rounded turbulence model.
I'm particularly interested in how it compares with the K-Omega SST model, Omega based RSM, and experimental data/or DNS data. Can anyone provide any insights? I have particular interests in using this model for buoyancy driven flows induced by a temperature difference. Imagine a vessel, with a hot bottom surface, and a cold top surface. Velocity is driven by the density difference. Are there any papers, key works I should be aware of? Thank you. |
OJ
Rep Power: 20 ![]() |
How about this to start with?
http://www.mech.kth.se/thesis/2000/p...fan_wallin.pdf http://cfd.mace.manchester.ac.uk/twi...-12531jos1.pdf |
Rep Power: 17 ![]() |
Some more references dealing explicitly with EARSM in APG BLs. It is indeed a good model I use it on a daily basis for rapidly rotating flows.
http://dx.doi.org/10.1016/j.ijheatfluidflow.2004.02.012 http://lib.tkk.fi/Diss/2004/isbn9512...9512269341.pdf |
Mr CFD
Have you done a comparison against SST? I know SST fails to sometimes predict secondary flows.
Sibel
Rep Power: 9 ![]() |
Hello everyone,
This is the first time that I deal with BSL EARSM model. My solution is not converged, actually it seems to convergence but the solution did not stop. Normallz asa far I understood ıt should take like k-epsion CPU time. I am using physical time scale and have changed between 0.05-200 but did not work. Solution is fluctuating around my defined rsm (10e-6) value Can anybody help me? Thanks! |
Rep Power: 144 ![]() ![]() ![]() ![]() |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 22:43 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 09:02 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
