Non-constant heat flux (as a function of wall temperature))
Old   February 23, 2014, 16:31
Default Non-constant heat flux (as a function of wall temperature))
Brandon
Laplace is on a distinguished road
Transient heat transfer modeling.
There are 3 thermoelectric coolers on the bottom of a chamber. The heat flux is a function of the temperature of the cooler (wall temperature), q=f(T), the larger the temperature is, the smaller the heat flux will be.
In other words, it's about how to create a wall heat flux function with respect to its temperature.
Can this problem be solved using expressions or functions inside CFX?
Laplace is offline   Reply With Quote
Old   February 23, 2014, 17:56
Use a CEL expression on the heat flux boundary. "Wall heat flux = 100 [W m^-2 K^-1] * T" should work as an example.
cfx
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
problem with constant wall heat flux openfoam1 OpenFOAM 6 January 13, 2019 09:18
How to set a initial temperature and constant heat flux at same BC's?? Jane FLUENT 4 October 25, 2015 13:01
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
