February 13, 2014, 03:32 |
ansys solver terminated with returne code -1
Abhishek Raj
Hello sir,
My work is related to fluid -structure interaction. for that i am using static-structural and Cfx for solid and fluid parts respectively. Simulation goes on and meanwhile it shows error and stops. The Error is as follows: +--------------------------------------------------------------------+ | Job Information | +--------------------------------------------------------------------+ Host computer: MECH-PC (PID:273768) Job finished: Thu Feb 13 11:20:47 2014 Total CPU time: 7.073E+01 seconds or: ( 0: 0: 1: 10.728 ) ( Days: Hours: Minutes: Seconds ) Total wall clock time: 7.000E+01 seconds or: ( 0: 0: 1: 10.000 ) ( Days: Hours: Minutes: Seconds ) End of solution stage. +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | ANSYS Solver terminated with return code -1 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The results from this run of the ANSYS solver have been written to | | C:\Users\mech\Documents\vasu_test_pending_tasks\dp 0_CFX_Solution_- | | 1\Fluid Flow CFX_001.ansys | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The results from this run of the ANSYS CFX Solver have been | | written to | | C:/Users/mech/Documents/vasu_test_pending_tasks/dp0_CFX_Solution_- | | 1/Fluid Flow CFX_001.res | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Warning! | | | | After waiting for 60 seconds, 1 solver manager process(es) appear | | not to have noticed that this run has ended. You may get errors | | removing some files if they are still open in the solver manager. | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. Please reply sir, what can be possible problem and how to remove the problm. Thank you. |
February 13, 2014, 11:52 |
#2 | |
Matthias Voß
Rep Power: 20 |
Check the displacement at the interface via Monitorpoints in CFX. Check the mapping of the InterfaceInterpolation--> should succeed for ALL points on the Interface. Get rid of every warning in the Ansys.err. |
ansys cfx solver exit with return code 1!!!!! | mhabibnia | CFX | 7 | August 19, 2013 04:53 |
How to execute an utility inside the code of a modify solver? | jmonsa13 | OpenFOAM | 2 | July 13, 2013 14:01 |
CFX solver manager quits with error code 255 | b.shuvayan | CFX | 16 | November 7, 2012 01:48 |
setFields.C within solver code | newOFuser | OpenFOAM | 3 | April 9, 2012 11:15 |
modify the source code of simpleSRFFoam solver | Pirlo | OpenFOAM Programming & Development | 0 | October 19, 2009 09:49 |
