WSS Monitor Points
Old   January 28, 2014, 10:40
Default WSS Monitor Points
Keyma
prikeyma is on a distinguished road
I am attempting to monitor the WSS components at a point on the wall during a transient simulation. I defined monitor points in the output control in CFX Pre as suggested in this forum. I chose the wall point based on the converged solution of a previous transient simulation using the same model geometry where I know the WSS is defined. However, I am unable to monitor the WSS component at the defined points in CFX solver. Each time I get the following message:
Monitor Point: WSSX
Domain: Default Domain
User specified location (x,y,z) : -1.289E-05, 2.130E-03, 7.450E-03
Assigned vertex location (x,y,z): -3.309E-06, 2.130E-03, 7.441E-03
Distance to specified location : 1.337E-05
Excluded variables from output variable list:
Wall Shear X
I don't understand why the Wall Shear X component is being excluded from the output variables list. I specifically selected the WSS components to be in the output variable list in order to monitor the points but for some reason the CFX solver is still unable to track the transient behavior.
Does anyone have a suggestion of how to fix this problem?
-Keyma
prikeyma is offline   Reply With Quote
Old   January 28, 2014, 10:46
Lance
Lance is on a distinguished road
Im guessing this location is inside the domain and not on the wall.
Lance is offline   Reply With Quote
Old   January 28, 2014, 11:00
Keyma
I suspected that might be the problem so I went to CFX post and used the probe tool to make sure the WSS components were defined at my selected Cartesian coordinate. I tried a couple different points and got the same result.
Old   November 16, 2022, 12:14
Default wss on wall in a stenosed blood vessel
naji
aiden_1995 is on a distinguished road
hi guys many questions in 1
how should i get wss on wall based on time during the solution in fluent(report definition)?
can it be on wall surface?
or it should be only on a point or line?if line how can i create it on a stenosed wall to include stenosis too?
facet average/weighted or another options which one should i choose?
aiden_1995 is offline   Reply With Quote
Old   November 16, 2022, 12:25
Gert-Jan
Gert-Jan will become famous soon enough
Ask the Fluent Forum
Gert-Jan is offline   Reply With Quote
Old   November 16, 2022, 12:35
naji
ok my bad
thanks for your message
cfx, monitor points
Calculating area of low WSS (<0.5Pa), fluent n.phililipova FLUENT 1 February 2, 2021 10:53
Map a WSS Contour on a Rectangle ashtonJ CFX 6 December 10, 2013 05:38
WSS and normal velocity gradient for the slanted pipe wanna88 FLUENT 2 October 1, 2012 23:34
WSS ASCII export problem Birkov FLUENT 1 July 27, 2009 15:09
WSS lack of convergence longchuan FLUENT 0 July 31, 2008 22:58
