htc
Old   January 19, 2014, 12:36
Default htc
mina
mina.p is on a distinguished road
hi
can anyone help me to draw htc for channel in cfx result>chart???
mina.p is offline   Reply With Quote
Old   January 20, 2014, 07:07
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
I'm not sure what you want. Your question isn't clear. Please read the FAQ.
If you're using CFD post usually you can insert a new line at the region of interest. Then plot a graph of heat transfer coefficient and distance.
JuPa is offline   Reply With Quote
Old   January 20, 2014, 07:58
mina
I did the same thing as you said
Insert a line and define it as a location in cfx chart
X Axis>x or lenght of channel
Y axis> wall htc
But after apply these changes i can't see any graph. The chart is empty
Can you please help me??
Old   January 20, 2014, 09:38
JuPa's Avatar
Mr CFD
Post some images. I don't know what you're trying to simulate. Just saying that you're simulating a channel is not enough information.
Old   January 20, 2014, 10:47
mina
a channel with a blade at inlet & wall temp:400k & fluid flow temp=293
i need the distribution of htc along the channel lenght
http://www.imageupload.co.uk/image/ZvK
http://www.imageupload.co.uk/image/Zrb
Old   January 21, 2014, 06:16
JuPa's Avatar
Mr CFD
Do you want wall HTC or wall external HTC? There's a difference.
Also, can you colour your boundary wall according to the wall HTC (or wall external HTC).
Your first image doesn't work. And I still don't understand what you're trying to do.
If you want help then take your time to provide us with all the necessary information, supported by images.
Old   January 22, 2014, 08:35
Bruno
brunoc is on a distinguished road
Y axis> wall htc
These variables only exist over the wall, so your line would have to be placed right over the wall. The easiest way to create such a line if your wall isn't straight would be as a polyline that's the intersection of a plane and your wall.
Also, for your HTC values to be correct, you need set the correct reference temperature as an expert parameter in Pre ('tbulk for htc') before your simulation started. Otherwise it will take the near wall temperature, which is probably not what you want.
brunoc is offline   Reply With Quote
HTC in Pipe flow subsemitonium CFX 6 May 6, 2013 23:00
HTC: How to choose reference temperature value halcyon STAR-CCM+ 3 April 12, 2012 12:46
Comparing HTC between CFX and hand calculation. turbotel CFX 1 March 3, 2011 10:56
HTC problem with multiphase shogologo CFX 0 April 21, 2010 10:26
Why so different 'htc' results...? azt CFX 0 November 9, 2005 17:15
