question on simulating rotating channel with a pressure gradient |
January 14, 2014, 09:35 |
Huang Xianbei
Rep Power: 14 |
hi everyone
I'm doing a simulation on the rotating channel in which the water is driven by pressure gradient. I think it's reasonably to use momentum source to implement the pressure gradient for the dimension of pressure gradient is just the same as the momentum source, kg m^-2 s^-2. The channel is rectangular and the rotating axis is set at the center of the left face where x=0, the x direction is the streamwise ,and the z axis is the rotating axis, y is spanwise. z and x direction are set with 2 pairs of periodic interfaces to make the flow fully developed. However, the results shows no asymmetry aross the y direction and the speed in the x direction is far away from expected, is this method wrong or in other words, no suitable in this problem? |
January 14, 2014, 17:57 |
Rep Power: 144 |
Please post an image of what you are modelling and an image of what you are seeing in the results.
Accuracy is an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
January 14, 2014, 22:45 |
#3 | |
Huang Xianbei
Rep Power: 14 |
the calculation domain is as the image shows[IMG]C:\Users\dodo\Desktop\QQ截图20140115104337.png[/IMG] here is the result, it's interesting to find that the slop of the calculation curve is the same as the slop in theory, but the y axis U is about 20 time larger than the theory |
January 14, 2014, 22:50 |
Rep Power: 144 |
The attached images did not work, please try again.
January 14, 2014, 22:53 |
Huang Xianbei
Rep Power: 14 |
January 14, 2014, 23:04 |
Rep Power: 144 |
No, you cannot see files on your local computer over the web. Not unless your PC is a web server that is
You will have to upload it to the forum. |
January 14, 2014, 23:39 |
#7 | |
Huang Xianbei
Rep Power: 14 |
the non-dimensional velocity U is done by u/ut, u is the dimensional velocity and ut is the friction velocity which is a constant, in the tunnel flow theory, the slope of the U curve is about -2w, y is the non-dimensional variable which implies the y direction,y=-1 and +1 refers to suction side and pressure side of the channel. The second picture is the calculation domain of the tunnel, the flow is in the x direction and the whole tunnel rotates with z axis which is set at the center of the left side of x direction surface. Both the x and z direction were set with a pair of translational periodic interfaces. |
January 14, 2014, 23:41 |
Rep Power: 144 |
I have no idea what the diagram means, what the graph is of and what your flow is. Please put some description on your images so we can understand it.
January 14, 2014, 23:50 |
#9 |
Huang Xianbei
Rep Power: 14 |
here is the results of DNS, and the condition I chose is Ro=0.5, it's obvious that the U is far away from the DNS results |
January 14, 2014, 23:53 |
#10 |
Rep Power: 144 |
You still have not explain what the graph is and what the diagram means. I just see a box.
January 15, 2014, 00:00 |
#11 | |
Huang Xianbei
Rep Power: 14 |
Thank you for your advise. I tried my best to explain the problem now, if there is any misunderstanding, I'll go on to explain more details |
Question on the boundary condition for open channel flow, please help! | ripperjack | OpenFOAM Running, Solving & CFD | 0 | September 13, 2013 12:44 |
Question Concerning Pressure Value (Pressure outlet) and Reference Pressure (Physics) | andy_flow | STAR-CCM+ | 1 | July 9, 2013 09:44 |
pressure gradient of a 2D periodic flow problem | Honey | FLUENT | 0 | September 19, 2012 04:21 |
Question about the dynamic pressure in the lifting/drag coefficients | tenkio | Main CFD Forum | 1 | May 17, 2011 12:23 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
