Additional variable in multiphase flow
Old   January 14, 2014, 05:17
Default Additional variable in multiphase flow
JESS
Raijin Thunderkeg is on a distinguished road
Hi, every1.
Now i have a problem about the additional variable in a two-phase flow. In CFX-pre, an additional variable has been set to Fluid Dependent on the Fluid Models tab. And transport equation is selected for one fluid on Fluid Specific Models tab. This equation is solved in the whole domain. But i just want it to be solved in the fulid specific region. How to do this? Can you give me some suggestions?
Thanks.
Raijin Thunderkeg is offline   Reply With Quote
Old   January 14, 2014, 05:48
But isn't the phase which has the AV present everywhere in the domain, even if it is just about zero in some places?
Old   January 14, 2014, 08:09
JESS
Thanks for your reply. Once i did a simulation on the mixing process in a water-air system using AV. When i display the contour of AV in CFD-Post, it presents everywhere. It is very strange because the tracer is just a species of water and the AV belongs to the water. Now i know i may have some misunderstanding here. What should i do to correct this? Multiply AV by a volume fraction?
Old   January 14, 2014, 17:58
Yes, to limit to one phase for post processing you could generate a new variable which is the AV * volume fraction.
Boudaries for bouynat driven flow with additional mass flux at inlet Charon CFX 2 April 27, 2013 09:02
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 11:14
Ansys 11.0 CFX - solving electric potentials and multiphase flow cfd_multiphyiscs CFX 2 March 10, 2010 14:43
Multi_component Vs Additional Variable Anurag CFX 2 February 4, 2005 17:45
additional variable mass transfer in CFX5.6 john CFX 1 February 14, 2004 01:30
