Problems in the deployment temperature
Old   December 17, 2013, 01:59
Question Problems in the deployment temperature
Arief
Zero is on a distinguished road
Dear all,
First im sorry if my poor language skills, i have a problem to simulation ansys cfx 2013. I have made an experiment on a cube and I insert an object into the cube. Cube was rather like the room and the object is a machine that has a temperature of 100 Celsius. In my pre CFX-cube into the air stream with a temperature of 25 Celsius and some other settings.
And at this stage of the CFX-post I made sebuat plane and I named plane 1. Variable on the first plane I set it as a base for cross-sectional temperature but the results do not spread on the plane, while if 1 variable on my plane to pressure or viscosity change there will be a deployment on the plane.
If you all have a solution please explanation, thank you..
Zero is offline   Reply With Quote
Old   December 17, 2013, 05:20
Can you post some images of what you are seeing, and include your CCL.
Old   December 18, 2013, 20:41
Arief
yes but may i know your address mail glenn because too large capacity if i send here ?
Old   December 19, 2013, 11:02
Arief
Result of Temperature (failed deployment at plane)
Old   December 19, 2013, 11:14
Arief
Result of Pressure (Success deployment at plane)
Setting model at cfx-pre
Old   December 19, 2013, 11:21
Arief
Setting Domain
Setting Material
Old   December 19, 2013, 17:26
Is the interface connecting the solid and fluid domains correct?
Is your simulation converged?
Do you need to run it for longer physical time? Convergence of CHT simulations cannot be judged by residuals alone. You often need to add imbalances as a convergence critereon.
Old   December 22, 2013, 21:14
Arief
Setting Interface
Have you ever done the experiment of heat transfer (CHT)?
Can you show me (tutorial) step by step about to add imbalances as a convergence critereon ?
Old   December 23, 2013, 07:35
Do the CHT tutorials provided with CFX. The heating coil is a good one.
Imbalances are an option under convergence control.
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
Free stream temperature in tube wall saharesobh FLUENT 2 November 19, 2012 08:32
Temperature went outside of its upper limit Atit Koonsrisuk CFX 0 January 8, 2004 12:43
Problems in CFX 5.5.1 Sulviyanti CFX 6 February 7, 2003 17:46
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
