Lift and drag coefficients for low reynolds numbers typical of VAWT |
December 17, 2013, 01:19 |
M. Abdul Akbar
Rep Power: 13 |
Dear All,
For the purposes of my research I need data of lift and drag coefficients for asymmetric NACA airfoil's for low Reynolds number's typical of Vertical Axis Wind Turbine's (VAWT). Is there any experimental data for the same ?. I know there is data for symmetrical airfoil brought out by the Sandia National Laboratories but is there a similar experimental result database for non-symmetrical NACA airfoil's ?? Thanks in Advance, Abdul Akbar |
December 17, 2013, 05:17 |
Rep Power: 144 |
Here is zillions of experimental results for squillions of airfoils.
http://aerospace.illinois.edu/m-selig/pd.html |
December 17, 2013, 07:40 |
M. Abdul Akbar
Rep Power: 13 |
Thank you Glenn Horrocks .....
airfoil, drag, lift, naca, vawt |
Effect of turbulence of flow on lift and drag coefficients | akku | Main CFD Forum | 1 | April 9, 2013 02:12 |
Lift & drag coefficient for NACA airfoil's for VAWT application | akku | Main CFD Forum | 0 | April 3, 2013 03:36 |
lift and drag coefficients around a ground vehicle | Pedro | CFX | 3 | September 5, 2012 19:31 |
Great lift coefficients but negative drag coefficient?! | nez | FLUENT | 0 | November 28, 2011 14:57 |
Lift and Drag Coefficients Reliability | Luis | FLUENT | 2 | December 27, 2005 15:45 |
