How to draw streamlines just around the wing?
Old   December 11, 2013, 09:00
Default How to draw streamlines just around the wing?
Antoni Alexander
zkdkeen is on a distinguished road
Hello everyone.
I want to generate streamline just around the upper and lower surfaces of a wing like this picture. I tried to use a plane inserted to start the streamlines but it is hard to control the position and shape of the streamline fields. So, what should I do?
zkdkeen is offline   Reply With Quote
Old   December 11, 2013, 09:58
Lance
Lance is on a distinguished road
One (tedious) way would be to release streamlines from points. Then you can control the streamlines you want to include by just moving the points.
Lance is offline   Reply With Quote
Old   December 11, 2013, 10:08
siw
Stuart
siw will become famous soon enough
Can you make a polyline along the wing leading edge and release the streamlines from that?
siw is offline   Reply With Quote
Old   December 11, 2013, 14:51
Edmund Singer P.E.
singer1812 is on a distinguished road
You can also generate a User Surface xx distance away from the actual surface you are interested in. Generate the streamlines off of the user surface. Adjust xx to what you would like to see.
singer1812 is offline   Reply With Quote
Old   December 12, 2013, 00:46
Antoni Alexander
Problem solved! Thank you all! Singer1812's way is really simple and effective.
[General] draw streamlines on the 2D slice hz283 ParaView 4 January 28, 2020 01:33
3D Wing Analysis Ed FLUENT 5 April 13, 2019 14:07
[ICEM] Blocking For Swept Wing air_engineer_arsenal ANSYS Meshing & Geometry 13 July 24, 2012 12:52
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails klausb OpenFOAM Meshing & Mesh Conversion 0 December 28, 2011 15:26
[Gridgen] Blocking topology for blunt wing siw Main CFD Forum 3 July 21, 2010 14:55
