How to define humidity in CFX
Like Tree5Likes
Old   March 12, 2023, 17:51
If you post an image of what you are modelling and your CCL or output file we can try to help you.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   October 17, 2023, 03:21
arun
arunvijay is on a distinguished road
Originally Posted by atulpat View Post
Thanks Sosat...
Except Temperature results now everything is OK (i.e. Relative humidity). Your expression is working in CFX Pst. I have used following expression for RH.
Insert→ Expression→ Pg
Definition = exp((20.386-(5132 [K]/T)))*132.29 [Pa]
Insert→ Expression→ Relative Humidity
Definition = (Water Vapour at 25 C.Mass Fraction/18.016)*(((Water Vapour at 25 C.Mass Fraction*18.016)+((1-Water Vapour at 25 C.Mass Fraction)*29))/Pg)*Absolute Pressure*100
Insert→ Variable→ RH and in expression set Relative Humidity
Now, if any anybody knows reason of temperature plot problem then please help me. Here Radiation model is not activated and sometimes I am thinking that due to this only I am getting slightly higher temperature.
Hi, from where you got the 20.386, 5132 and 132.29 values for equation of Pg. Could you please share ?
arunvijay is offline   Reply With Quote
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 22:13
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
Can I define mutistep reaction mechanisms by CFX? Lixian CFX 0 November 19, 2008 11:43
Add user define monitor in CFX Solver Zaidun CFX 0 April 17, 2006 15:57
How to define STOKES equation in cfx? kerl_liu CFX 1 April 3, 2006 23:54
