CFX 11.0 "Vector Variable Normal” Does not Rotate with Domain? User Surface Moving
Old   November 14, 2013, 16:41
Default CFX 11.0 "Vector Variable Normal” Does not Rotate with Domain? User Surface Moving
jrl4444 is on a distinguished road
Attachment 26811Bug or just the way it is? CFX Post 11.0
Problem ….User Surface moving out of location as domain rotates in a transient run.
See attached example images for quick understanding of where I am hung up. Transient run, rotating square, user surface offset inside domain, as domain rotates surface moves out of location. After investigating I find that
Vector Variable Normal on the model surfaces does not rotate with the domain if I advance steps using time step selector or run an animation.
Vector Variable Normal does update if I load any time step under file command Load Results.
This looks scary to me thinking about Post calculations / expressions that may depend on this very basic variable updating as a domain is rotating.
Clearly Post does the calculation for Normal from a surface for every node when a file is loaded, is there a way to force a recalculation as new time steps are advanced / the domain moves?
I have looked and looked for a setting or workaround:
Here is what I have considered so far.
Create my own variable MyNormal by Frozen copy of Normal Plus domain movement. ?? I don’t see an easy way to use MyNormal to place the Use Surface.
Set up a batch and load every trn file one by one outputting single image frames to stitch together later.
Load the user surface from file but then I need to transform the surface every step to move with the model. I am guessing there is a fairly simple way to do that but a call for recalculating the Variable Normal would be so much cleaner.
Thanks for your time
jrl4444 is offline   Reply With Quote
Old   November 14, 2013, 17:32
Does this still happen in the current version of the software?
Old   November 14, 2013, 18:10
(Does this still happen in the current version of the software?)
I have no idea? The rotating square was a simple example to test it.
I only have 11.0 32 and 64 bit, both of these have this problem, I tried on a couple different machines different operating system all same results. I was doing a moving mesh project that included rotation. I thought this problem was do to a moving mesh issue so I set up the simple standard rotating square domain and was shocked to learn what I found. Scary because most rotating domains are round, the problem is difficult to notice on a tangent running surface.
Does it seems like a bug to you?
Old   November 14, 2013, 18:14
It could be a bug - obviously you have to check your rotation point.
But nobody cares about bugs in old versions of software. If you find a bug in the current version then report it and hopefully get it fixed, but nothing will happen in old versions.
Old   November 14, 2013, 18:46
My Rotation point? 0,0,0 rotating about Z axis, and I did check it but true normal from a surface is Normal regardless of rotation point. Perpendicular in 3D space from a flat surface, somewhat more complicated on curved or irregular surface but still a definable vector from a node based on adjacent nodes . That is what the Variable Normal in CFX is supposed to be right?
Well newer version is not currently an option for me so digging deeper, been awhile but have done a little perl programming. CFXPostRules.ccl is my starting point but looks to be deeper than that.
Any help in a direction to go would be great, Thanks
rotating domain, user surface, vector variable normal
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Free surface modelling under CFX 4 Dahong CFX 2 June 23, 2002 00:07
CFX 4.4 New free surface option Viatcheslav Anissimov CFX 0 April 3, 2002 07:27
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
CFD Short Course & CFX User Day Chris Reeves CFX 0 September 11, 2000 09:53
