Jānis Ratnieks
Rep Power: 0 ![]() |
I am doing a transient simulation in CFX on a cluster (no GUI), I make a .def file where I say that I want some .trn files generated, but when the solver finishes, there is only a .res and .out files and nothing more, so I can only get the final time step, not all the rest of .trn files I wanted to generate. It seems that CFX is not generating them. How do I tackle this problem? Thanks in advance, Jānis Ratnieks |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Have a look at your settings for transient results files. Did the simulation go far enough to get to the first transient results file? Did you specify which variables go in it then specify nothing?
cfx, cluster |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 20:12 |
problem in writing/saving files | infinity_28 | Main CFD Forum | 0 | February 6, 2013 12:39 |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 14:39 |
Problem running OF on cluster | Rebecca513 | OpenFOAM Running, Solving & CFD | 14 | August 26, 2012 18:09 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
