January 12, 2014, 06:18 |
#21 |
Rep Power: 144 |
If your flow is near turbulence transition it is going to be very tricky. Normal turbulence models do not work well in this region (but some work better than others - SST is far better than normal k-e for instance).
You are probably going to need a transient LES style simulation, and a laminar flow model may well be as good as anything. For example my PhD thesis looked at exactly this sort of thing in a piston/cylinder arrangement - see http://hdl.handle.net/10453/20133 in chapter 6. |
May 19, 2014, 12:25 |
Good point
#22 |
Fahad Khan
Rep Power: 16 |
I am trying to simulate thermocline formation in a tank and so far i have tried K-e and SST model with no luck of matching my experimental results. I will try LES and post my results.
Thank you for your input and sharing your thesis, Fahad |
May 21, 2014, 04:15 |
#23 |
Deutschland
Rep Power: 13 |
I have successfully done my simulation for a 6.5 m³ tank with a stratification device with diameter 125 mm and a volume flow of 1 m³/h. I used laminar flow and the results match the experimental data quite well (see attachment). The green line is the starting temperature distribution, the yellow line the inflow temperature. The purple curve shows the result of the experiment (after 3 h 7 min). Finally, the red line is my simulation result. I'm still not sure how to proceed with higher volume flows. If you have new insights concerning this problem, please let me know. Best regards. G. |
May 21, 2014, 09:09 |
Flow parameters
#24 |
Fahad Khan
Rep Power: 16 |
Hello G,
what is you Re and Fr number and what time of inlet shape are you using? From what i have seen now, even at Re= 1000 the flow seem to be turbulent. Regards, Fahad |
May 21, 2014, 09:48 |
#25 |
Deutschland
Rep Power: 13 |
the type of inlet shape can be seen in the attachments of post #7 and #17 in this thread. What dimensions do you use in Re and Fr? Diameter of stratifier or tank or some other dimensions? Best regards. G. |
October 22, 2015, 11:23 |
3 d of triplex pipe Geometry
#26 |
Rep Power: 10 |
Hi all
i want to generate 3 d triplex pipe by workbench but i have problem with faces generation any help please |
Need Help! High pressure Gas discharge from tank to tank through a pipe | superarthur86 | FLUENT | 2 | June 16, 2017 10:22 |
simulation of free surface of stirred tank using vof | jamalf64 | FLUENT | 41 | May 24, 2016 15:04 |
Roll Tank Simulation | Sam | CFX | 14 | February 15, 2009 20:21 |
Pressure BCs for rasInterFoam tank fillingdraining problem | kwardle | OpenFOAM Running, Solving & CFD | 8 | September 17, 2008 14:37 |
simulation of a stirred tank | hu | CFX | 0 | February 17, 2001 07:23 |
