Initialization Additional Variables for time integration |
January 23, 2014, 04:44 |
Time integration
#21 |
HLo
Rep Power: 13 |
Hello Atze,
I did some experiments as well, comparison of integration with: A) an additional variable and B) with a fortran function in both transient and steady state runs. The fortran routine implements trapezoidal rule and takes account of timestep length. transient, constant and varying timestep lenghts: both solutions do their work but with "slightly" different results A) the very first integrated value of a quantity q is calculated as: q0 + q*dt1 (q0 is initial value dt1 is 1st timestep length) B) the fortran implemetation uses trapezoidal rule so gives 1/2*(q+q0)*dt1 -this main deviation is kept the entire simulation if one doesn't supply a "dummy" initial value q0 -minor deviations appear but these may be explained this way: fortran gives 1 output value for 1 input quantity, whereas the AV solution uses a volume integral or mean value over a output quantity with spatial and/or numerical "noise" inside steady state: -the deviations found in transient are the same -the result gives a reasonable integration value, if physical timesteps are chosen - On automatic timesteps a "false timestep" is used, but there is no way to access it from fortran, so I expect the compensated (see conclusion) AV solution to be of advantage, not beeing sure how the intgrated value has to be interpreted, when no "real" time value is given conclusion: If one consideres to post process the integrated quantity in CFX-Post an AV ist needed anyway, one might prefer the AV solution, with an initial value which is minus one half of the expected quantity times 1st timestep: -0.5*q*dt1. Unfortunately the initial value cannot be expressions, so a value has to be calculated in advance. Both solutions give good results in transient runs, steady state runs need further investigations and considerations how the results have to be interpreted |
loop, time integral, wall condesation model |
ADDITIONAL VARIABLES LIMITERS | N.P | CFX | 5 | December 1, 2011 08:47 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 10:14 |
additional variables' effect | ariel | CFX | 9 | April 2, 2008 01:41 |
user SUBROUTINE for additional variables | Tuks | CFX | 0 | November 8, 2005 03:09 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
