compare theoretical, experimental, analysis result
Old   October 25, 2013, 07:22
Smile compare theoretical, experimental, analysis result
kim dong mi
ekfzha55 is on a distinguished road
hi, I want to have advice.
I are compared theory, experiment, and analysis .
Model ; image "+ ~ +" Section, but only
L(length) : 58.6 mm
B(height) : 0.6mm
W(width) : 5.0mm
μ(viscosity) : 0.172 Pa*s
r(specific weight) : 1.118 g/cm3
Q(flow rate) : 3.7 g/s
http://blog.naver.com/ekfzha555
The resulting value of theory ;
Pe = 12μQL/(wB^3 )
= (12 ∗0.172 ∗3.7∗ 58.6)/(5 ∗ 〖0.6〗^3 ∗ 1.118∗〖10〗^(-3) )
= 3.7bar
The resulting value of experimental ; Pe = 3.7 bar
The resulting value of analysis CFX ; Pe = 2.68 bar
setting ;
Domain : fluid / Air -two component
Reference P. 1atm
Initialization : velocity 0 m/s
relative pressure 0atm
Volume fraction - fluid(0) / Air(1)
inlet : mass flow rate 3.7g/s
Volume fraction - fluid(1) / Air(0)
outlet : static pressure 0bar
wall : no slip
why is that ? 1bar difference ?
ekfzha55 is offline   Reply With Quote
Old   October 25, 2013, 07:51
Lance
Lance is on a distinguished road
I have no idea what you are modeling, but:
http://www.cfd-online.com/Forums/cfx...ease-read.html
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Lance is offline   Reply With Quote
Theoretical analysis and modelling of gas-solids Langa Ntetye Main CFD Forum 0 December 13, 2007 07:10
NACA0012 experimental results. Kyung-Seok, Kim Main CFD Forum 0 March 13, 2006 06:46
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 04:03
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 18:46
Is CFD Science or Art ? John C. Chien Main CFD Forum 36 October 5, 1999 13:58
